Old 02-07-2023, 06:35 PM
napa68 napa68 is online now
Default Sun Temp Gauge Technical Help
Looking for a bit of troubleshooting guidance on my Sun blueline temp gauge.
Took the car apart in fall for an engine freshening. Gauge worked good then (reasonably accurate) with what I felt was an original sending unit.
Fast forward to this week. I get the car running, but the gauge is DOA. I have power going to the gauge, and the wire running from the gauge to the sender has continuity with no resistance of sort.
In short, are the gauges that fickle? I noticed the engine builder coated the sender in teflon paste. The sender measures about 13 ohms from base to terminal at room temp (63 degrees).
Thanks,
Tim
Old 02-07-2023, 07:09 PM
The sender may not be grounding with too much paste on the threads. With the engine warm, hold a screw driver against the body and touch the cylinder head, Have Tracy watch the gauge for movement.
napa68 (02-07-2023), SuperNovaSS (02-07-2023)
Old 02-07-2023, 09:03 PM
Also, if you quickly ground the sender wire with the ignition on the gauge needle should flicker.
Jason
napa68 (02-07-2023)
Old 02-07-2023, 09:30 PM
There is power going into the gauge, but nothing coming out going to the sender. I checked for power going to the sender first of all (nothing) and then again at the output on the back of the gauge.
I then took it a step further to check for resistance in the wire going from the back of the gauge to the sender, and it's perfect.
Old 02-07-2023, 09:42 PM
juliosz's Avatar
juliosz juliosz is offline
The wire going to the sensor is ground only. As the sensor heats up, it gradually opens the path to ground causing the gauge to display the current coolant temp.
The Following 5 Users Say Thank You to juliosz For This Useful Post:
69M22Z (02-07-2023), napa68 (02-07-2023), PeteLeathersac (02-08-2023), SuperNovaSS (02-08-2023), turbo69bird (02-09-2023)
Old 02-08-2023, 03:53 PM
That sensor is the same as a fuel level gauge, it varies the ohms/volts allowed thru it for the gauge to read. The wire has to supply the power to do that. If the wire out of the gauge is dead, there is another issue. Hopefully, the wire didn't get grounded with ignition live during the engine bay cleaning and shorted the gauge out. Is there an in-line fuse that may have blown ??
Old 02-08-2023, 04:29 PM
There is not any power at the terminal coming out of the gauge. Something in the gauge is amiss. I'll pull it apart and investigate.
Old 02-09-2023, 06:07 AM
Did you try grounding the sender wire to see if there was movement on the gauge needle?
Thanks,
Jason
Old 02-09-2023, 06:09 PM
turbo69bird's Avatar
turbo69bird turbo69bird is offline
So is this correct?
Old 02-09-2023, 11:00 PM
juliosz's Avatar
Originally Posted by turbo69bird View Post
So is this correct?
Yep, I’ll break down the diagnosis,
1. Ignition On, using a test light connected to ground, probe the battery terminal at the back of the gauge. Test light should light up. If not, check fuse. If fuse good, check wire.
2. If you have battery at the gauge, ignition On, find a GOOD ground and jump to the sensor terminal at the back of the gauge. Gauge needle should sweep to its limit. If it does, gauge is good, move to step 3. If it does not sweep, replace gauge.
3 Ignition On, Again, using a GOOD ground, disconnect the sensor and jump from ground to the sensor wire terminal. If the gauge pegs again, sensor wire is good, go to step 4. If it does not, you have an open circuit in the sensor wire between the gauge and sensor.
4. Using a volt ohm meter, check for continuity between the body of the sensor(not the center terminal) and the intake manifold, you should have continuity, if you do, the sensor is bad. If you don’t have continuity, remove sensor and clean excess gook from threads, reseal and reinstall.
The Following 3 Users Say Thank You to juliosz For This Useful Post:
NorCam (02-20-2023), SuperNovaSS (02-10-2023), Xplantdad (02-09-2023)
