Old 02-08-2023, 12:14 AM
HuggerSS HuggerSS is offline
Default 1968/1969 parts
Clearing some miscellaneous parts off my shelves off;
NOS 207 TI coil sold
67/68 Z fast ratio power steering pitman arm 3908391 $350
AM/FM transistor $150
1969 FM antenna post with large top ball $200 each
1968/69 booster vacuum fittings $50 each (The fitting to the right is sold)
Single crimp NOS rear brake hose sold
1969 Chevelle tilt wheel with the correct 1969 square lock script $300
1969 Camaro kick panel speaker grills sold
1968 Z28 water pump bypass fitting $75 each
1969 Camaro straight early headrest VGC $100
1969 Camaro trunk light sold
1968 Z28 glove box door with 15 in tire pressure sticker $350
1969 headlight washers and parts $50
NOS 1968 front license plate bracket $50
1969 crossram foot pedal $100
1968/69 original RS lower tank, very clean $75
If parts don’t sell, I will be open to offers. To the best of my knowledge, all of the parts are original.
The Following User Says Thank You to HuggerSS For This Useful Post:
olredalert (02-08-2023)
Attachments - The Supercar Registry FC5E5464-B025-48C7-9754-3F4C525F25E3.jpg FA4E1C5D-D60A-4AC1-A8A9-8711BCFA02D5.jpg F1BEF0F4-2AD0-4C3A-A741-0A132FE4530A.jpg F163DAD2-64DF-45F2-A5B6-9D16B4B6C9EA.jpg
