Old 02-25-2023, 12:58 PM
scuncio scuncio is offline
Default '67 Mustang Fastback C-Code Project, 289/4-sp
Looks pretty solid in the pictures, just super dirty with interesting surface rust on the horizontal surfaces, which make me believe it might have sat outside with a tarp over it for some time.
The auction is in Chicago, so it might be worth asking the seller for some underbody pics. Sounds like it the car was his dad's, who had passed.
Link to 1967 Mustang Fastback eBay auction
7T02C202404
L_e_e (02-25-2023), PeteLeathersac (02-26-2023)
Old 02-25-2023, 04:06 PM
L_e_e's Avatar
L_e_e L_e_e is offline
Would do wonders if they would of cleaned it out and did some light detailing on it before listing it for sale.
The Following 4 Users Say Thank You to L_e_e For This Useful Post:
dykstra (02-28-2023), olredalert (02-25-2023), PeteLeathersac (02-26-2023), scuncio (02-25-2023)
Old 02-25-2023, 05:24 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Originally Nightmist Blue (dark blue), not red.
The Following 2 Users Say Thank You to 1967Z28 For This Useful Post:
Old 02-25-2023, 09:17 PM
Isn't a "C" code a 260, or was that only in 65 + 66 Mustangs? Could one even get a 260 in 1967? What is a IPO 289? If the seller is trying to say HI PO 289, wouldn't that be a "K" code? I didn't think a "K" code 289 was available in 1967. My Father purchase the 67th. 1964.5 Mustang made on April 17th, 1965. I believe the Mustang was released on April 21, 1965.
Bill
Old 02-25-2023, 09:25 PM
luzl78 luzl78 is offline
Bill
They did make a k code in 67 but was rare.319 we’re made and 205 were 4 speeds. 472,209 mustangs made in 67.
Old 02-26-2023, 12:59 AM
I think you mean 1964, not 1965. And no, the 260 was not available in 67.
Bill Pritchard
Old 02-26-2023, 01:04 PM
ls6owner ls6owner is offline
A C code is a 298 2 barrel, rated at 200 hp, if I remember correctly.
Happiness is having Chevelles, Novas, and Mustangs in the garage, and a wife that is OK with it all!
Old 02-26-2023, 03:02 PM
1967Z28's Avatar
That's correct for a C code in that era. The A code Mustang was a 289 4bbl that had 10:1 compression and 225hp.
Old 02-26-2023, 03:52 PM
Yes, I meant to say 1964, and the "D" code was an early (1964.5 only) 289 4 bbl with 10.0 compression and a generator. Thanks for the correction.
Bill
The Following User Says Thank You to Big Block Bill For This Useful Post:
Bill Pritchard (02-26-2023)
Old 02-26-2023, 05:18 PM
A12pilot's Avatar
A12pilot A12pilot is offline
I think his confusion on the listing about the IPO maybe a late release of the stock and it being retracted before hitting the exchange. Wait, what? We’re not talking about an Initial Public Offering?
But seriously, the confusion with him on his info may be on the body buck tag. The VIN shows 7T02C, meaning 1967 Metuchen NJ built, Fastback, with a 200hp 2bbl 289 engine. What the body buck tag shows is a K so maybe he assumes it was a K-Code (HiPo 289) engine not realizing that is the color code of the car, Nightmist Blue.
Looking at this tag, it decodes as follows (I’m going by memory…):
X - customer ordered car (I think, versus a dealer order which shows D)
213 - rotation number (the 213th car built that day)
30 - Welding Bay number where assembled
821 - August 21st build
7T02Cxxxxxx - VIN
63A - Fastback, standard interior (although one will note it was outfitted with the Deluxe brushed aluminum dash trim at some point)
K - Nightmist Blue
2A - standard black vinyl bucket interior
SP - Stereo Premimum (AM/FM)
DB - Disk brakes
A couple things to note: plastic cowl cover. That means rotted cowl which means rotted floors and rotted torque box. Interior shot showing upper door jamb and rust hole in jamb. Look at the engine bay: how did the cowl to firewall pinch weld get so dented up? I can almost guarantee on this car if the exterior surface is rusted there is plenty under that needs attention.
Hopefully that helps!
Cheers
Dave
The Following 3 Users Say Thank You to A12pilot For This Useful Post:
Big Block Bill (02-27-2023), dykstra (02-28-2023), Lee Stewart (02-26-2023)
