Old 05-17-2023, 11:55 PM
RALLY RALLY is offline
Default Used shock absorber sprayed with undercoating
I have a used set of shock absorbers that have some undercoating on them. What do you use to loosen this undercoating to remove?
Old 05-17-2023, 11:58 PM
napa68 napa68 is offline
Go jo hand cleaner
RALLY (05-18-2023)
Old 05-18-2023, 01:40 AM
ban617 ban617 is offline
Depending on how much perhaps a wire wheel.. I have used a wire brush & propane torch to remove under coat from the bottom of the body before …
Old 05-18-2023, 03:08 AM
Lacquer thinner or acetone.
If you are trying to get the undercoating off WITHOUT damaging the underlying paint, them make sure the paint isn't lacquer based. Test on a small inconspicuous area.
"Goof Off" is another option, but will require more effort.
Old 05-19-2023, 04:03 PM
Dan you can also use Mineral Spirits, always worked for me.
Old 05-19-2023, 04:04 PM
Thanks Mark, very good info.
Old 07-11-2023, 04:57 AM
desertedboat desertedboat is offline
Perhaps a wire wheel, but it depends on the budget. Try it out in a hidden spot.
Old 07-11-2023, 02:23 PM
Copious amounts of Goof Off is pretty gentle, but time consuming. It won't touch the paint if that is your goal.
Owned since 1978 - First Car
Old 07-11-2023, 04:45 PM
scuncio scuncio is online now
3M Adhesive Remover is some of the best stuff on earth for a job like this.
Old 07-11-2023, 07:31 PM
Donnie's Avatar
Donnie Donnie is offline
Diesel fuel
69 SS L78 Chevelle
70 SS 396 Chevelle
