Old 08-21-2023, 06:57 PM
169indy's Avatar
169indy 169indy is offline
Default Factory Single Crimp REAR brake FLex Line
One each take of (1983) single crimp flex rubber rear brake line from: Off the road and in a garage since 1981. I know because I just helped a friend remove this from His vehicle.
1967 Camaro 12 bolt Rear. LOS 1967 396/375 4K Car currently under re-restoration.
UPC 5/B2
PN Not sure: 3910720 or 3898234 ??
NO Brass block included: Hose is the More difficult to source in this condition.
Could this work on a 68 also, I think so.
Cleaned up: Intact, Threads and seat in Great condition, Hoes Flexable (NO! Cracking that I Can SEE!YEA) and gentley aged WITH two sets of stenciling still visible. The Hose is clear and flow confirmed via Air compressor test.
Two (2) visible INK manufacture stamps,, Hose has two Stencils; One side Wide white continuous line, Other side narrow white broken line with Part number Seen. "B16086" Metal ends lack the Aged Plating finish but present well and both ends have Metal indent manufactures stamps visible.
Offering now "as is" prior to sending to Zinc Plater for end plating- renewing then relisting, to see if customer would prefer PRIOR to plating for their survivor judged car.
150.00 (*Subject to revision AFTER plating)
Paypal F&F + shipping from 98311 USPS
Thanks
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry DSC04744.jpg DSC04743.jpg DSC04742.jpg DSC04741.jpg
Old 08-21-2023, 10:24 PM
TerryD's Avatar
TerryD TerryD is offline
Hi Jim, I’ll take the flex line if still available. Sending pm.
Old 08-22-2023, 12:14 AM
169indy's Avatar
Sold Pending (8/21/2023)
69 Los Z11
68 SS/RS 396/325
68 Los Z28
