Old 09-10-2023, 08:22 PM
Default 1971 350
This is a 1971 Chevy 350 with 4 bolt nodular iron 2482 bearing caps. It had not been disassembled before we took it apart. It still had the original head gaskets and bearings in it. The block is standard bore with .004 to .007 wear on the cylinders. The crank is cast iron and is standard on rods and mains. The heads are 3973487 with no X. Block and heads are cast in Dec. 1970. It has the high performance 8 inch balancer and the O rods. Includes a Edelbrock Performer intake and a QuadraJet carburetor. $700
Attachments - The Supercar Registry 376224891_6956286141057785_4899127388103726251_n.jpg 374263468_6519774984810236_3386613971051232427_n.jpg 374263468_6497843716936204_371972207657248455_n.jpg 374228148_6488126307930221_1199890229987681_n.jpg
