Old 10-01-2023, 12:06 AM
RALLY RALLY is offline
Default Brake Master Cylinder rebuilder?
Looking for a good brake master cylinder rebuilder for a 72 Nova? Any good businesses that do this you would recommend. Thanks you.
Old 10-01-2023, 03:30 AM
If the bore has zero pits, then just about anyone can rebuild it.
If the bore is pitted, then White Post Restorations.
I had them sleeve and rebuild front wheel cylinders for my 49 Studebaker dump truck, as they are not available new.... any where.
I rebuilt the MC in my Z 15 years ago, and it is leaking again, so getting ready to pull it and send it to White Post.
Old 10-01-2023, 05:27 AM
X66 714's Avatar
X66 714 X66 714 is offline
Here's the guy to go to. Mike Gibbons
https://www.brakeboosters.com/
Joe
Old 10-01-2023, 08:08 AM
Tuna Joe Tuna Joe is offline
Joe
Mike did an excellent job on my ‘69 Corvette MC
The Following User Says Thank You to Tuna Joe For This Useful Post:
X66 714 (10-01-2023)
Old 10-01-2023, 08:44 PM
Thanks guys, appreciated.
Old 10-01-2023, 09:56 PM
66BoxNova 66BoxNova is offline
Mike Gibbons , great work
Old 10-01-2023, 10:30 PM
67since67's Avatar
Mike Gibbons is top shelf!!
I've also had great results with Karp's Power Brake in Chino CA, and with White post. Last I knew Karp's uses SS sleeves while White Post uses brass, if it matters to you. - Bill W
Old 10-02-2023, 01:27 AM
All great info, thanks.
Old 10-02-2023, 09:10 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Yes Mike Gibbons is awesome!! A guy that actually enjoys what he does!!
The Following User Says Thank You to Jonesy For This Useful Post:
mhm1966 (10-02-2023)
Old 10-04-2023, 03:13 PM
Had White Post do mine off the 69 Z and so far, everything is good.
