Now that Freddie has made sense of my broken tailhousing, I'm wondering which material for a new driveshaft. The engine is a 496 capable of 600 hp/torque. That seems to be the area where certain things get more expensive. Looking for recommendations of material and known, reliable, sources to order from.
Thanks !
I'm using a Strange steel shaft in my car. I used several Inland Empire Driveline shafts in customer's cars over the years. Denny's and some others are nice too. Aluminum is nice, but more expensive. Go with the 1350 joints. You'll need to swap the yoke on the rear end and get a new one for the transmission, but it's worth it. Be sure that it's high speed balanced. The M20 won't hold up to that much power if you use slicks.
Freddie 1969 Camaro RS/SS396 (427) 4 speed Last edited by big gear head; 10-24-2023 at 02:56 AM. |
The Following User Says Thank You to big gear head For This Useful Post: | ||
Too Many Projects (10-24-2023) |
X2...what Freddie said
![]() Quote:
The Following User Says Thank You to olredalert For This Useful Post: | ||
Oh, Boy, looking at Strange wasn't a slippery slope, it was a cliff...
![]() Complete 3.5" driveshaft with 1350 yokes, 4.11 gears with install kit and alloy axles. I shouldn't need any more than that to have a reliable driveline assembly, but..... I need a part time, winter job again... ![]()
Would be best to go with someone that balances driveshafts at high rpm if car will ever be raced. If you're only going to car shows, balancing rpm doesn't really matter.
...................... John Brown This isn't rocket surgery..... |
----Name of the place is CCI Driveline. Ph#586-716-1160. I know a lot of serious drag racers use them. I'm not sure but think they can high speed balance. Give em a call.....Bill S
The Following 2 Users Say Thank You to olredalert For This Useful Post: | ||
L_e_e (10-31-2023), Too Many Projects (10-24-2023) |
I've used the same people as Freddie. Cannot go wrong
The Following User Says Thank You to napa68 For This Useful Post: | ||
![]() Quote:
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
John Brown (10-24-2023) |
My '67 I am running a 3.5" steel driveshaft.
VRN in Lake Bluff IL makes the DS's for Strange, you could always email them for a quote. |
