Old 10-29-2023, 01:49 PM
Default Hone O Drive
Does any one which gear lube should be used in the Hone O Drive?
Thanks Dan
Old 10-29-2023, 02:21 PM
I believe it's GM dexron automatic transmission fluid.
Old 10-29-2023, 02:34 PM
Found this pic and it does look like it's auto trans fluid. hard to read if it specifies Dexron... maybe someone can enlarge it.
Old 10-29-2023, 02:37 PM
As a side note, these were originally built only for Ford applications, so it may want FOMOCO fluid ? The 300 universal model came along well after the initial introduction, so I would believe the lube requirements would be the same as the earlier Ford models...
chevyandpontiac (10-30-2023)
Old 10-29-2023, 03:28 PM
SS69chevelle SS69chevelle is offline
The 300 hone o drive instructions i have identify one quart of ATF automatic transmission fluid and refers to instruction 11.
instruction 11 reads; "Fill the HONE-O-DRIVE with 1-3/4 pints of Automatic Transmission Fluid. Never allow oil level to be more than 1/8" below oil fill hole. Check level at each engine oil change, and watch for possible seal damage at both ends."
Hope this helps take care Andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following 2 Users Say Thank You to SS69chevelle For This Useful Post:
chevyandpontiac (10-30-2023), COPO (10-29-2023)
Old 10-29-2023, 05:39 PM
Yes, it is ATF. I'm not sure it matters if it is Dextron or Motorcraft since there are no clutches to be concerned with.
Jason
The Following 2 Users Say Thank You to SuperNovaSS For This Useful Post:
chevyandpontiac (10-30-2023), L_e_e (10-29-2023)
