Old 10-31-2023, 11:31 PM
Default 69 396/325 Qjet to Manifold Gasket Question
Looked thru my service manual, overhaul manual, AIM, and Rochester Carburetor books and still can't find anything that delineates what type and how many gaskets are used between the carb and intake manifold. I have a thinner gasket that has the long elongated slot from side to side just forward of the primary throttle bores, a thicker gasket with the same slot that looks like it may have metal or asbestos or something impregnated in it, and a thin metal (stainless steel?) shim shaped like the gaskets but minus the elongated slot. Trying to replicate factory configuration. Any help appreciated.
Bill Pritchard
Old 10-31-2023, 11:54 PM
X66 714's Avatar
X66 714 X66 714 is offline
The thin stainless one goes against the carb. The fiber steel goes on top of the manifold. Then the carb. L35 A6 in AIM...Joe
Bill Pritchard (11-01-2023)
Old 11-01-2023, 12:10 AM
Thanks Joe! Found it in my Rochester Carburetor book in the interim also. And I see now that it's illustrated in my AIM under the L34 (350hp) option.
Bill Pritchard
X66 714 (11-01-2023)
