Old 11-03-2023, 07:53 AM
Default Removing/Replacing Delco Shock Bushings
Looking for advice, video on removing Rear Upper Cross
Bar and Bushing , then Reverse The Process
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 11-03-2023, 01:20 PM
Getting the old one out shouldn't be an issue. I would use a utility knife and cut the expanded heads off and start drilling holes in the bushing until it is pliable enough to press out. Installing the bushing alone should be fairly easy and then lubricate the bar with a strong solution of dawn soap and press in. The assembly would be after any necessary rust removal and coatings applied to the metal parts.
69M22Z (11-03-2023), Steve Shauger (11-03-2023), X66 714 (11-03-2023)
Old 11-03-2023, 03:31 PM
SS427's Avatar
SS427 SS427 is offline
If you are going to restore your shocks back to original Chuck, make sure you paint the shocks after the bushings are installed.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
enio45 (11-03-2023)
