Old 11-05-2023, 05:47 PM
Dusk Blue Z Dusk Blue Z is offline
Default 69 Camaro Deluxe Interior Door Spring
Assembling my 69 Z10 with deluxe door panels. I can't remember where this spring goes, it was in the door parts bag. I am missing one for the other side. I am thinking it is something for the locks??? Any info or pictures would be a great help. Thanks.
Mike
Attachments - The Supercar Registry Screenshot 2023-11-07 090819.png IMG_6977.jpg 20231105_122021.jpg
Old 11-05-2023, 06:33 PM
169indy's Avatar
169indy 169indy is online now
My First Gut reaction is it is a Bucket Seat sliding Rail lever detent return, they were Yellow and appx this size.
Others might better ID.
but that is my First initial thoughts??
Well the Hook length looks to long for a Seat item,,,,,,,,,,,,,,,,,,,,
JIM
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
mhm1966 (11-05-2023)
Old 11-05-2023, 10:01 PM
Thanks Jim. This spring is light weight compared to the seat springs and it has a cloth covering like the rod from the inside door handle to the latch. I would say it would be to keep a slight tension on some part?
The Following User Says Thank You to Dusk Blue Z For This Useful Post:
169indy (11-06-2023)
Old 11-06-2023, 01:33 AM
X66 714's Avatar
X66 714 X66 714 is offline
It attaches to the door control & then there is a small hole. It's inside the door, not behind the door panel. I tried to look for a picture when I did my car but didn't have anything...Joe
Old 11-07-2023, 02:18 PM
Thanks Joe. I found a picture of the one original door, and when I zoomed in I could see the spring installed. Not sure why Chevy would have added that small spring when there is a large spring on the release handle.
The Following 3 Users Say Thank You to Dusk Blue Z For This Useful Post:
169indy (11-07-2023), dykstra (11-07-2023), X66 714 (11-07-2023)
Old 11-15-2023, 07:17 PM
Edgemontvillage's Avatar
JIM
The Camaro seat slider spring is painted bright yellow however it’s a thicker gauge and different dimensions than the deluxe interior door mechanism helper spring.
The Following 2 Users Say Thank You to Edgemontvillage For This Useful Post:
169indy (11-15-2023), Dusk Blue Z (11-16-2023)
Old 11-15-2023, 11:52 PM
Rsconv68 Rsconv68 is offline
You can also see the cloth covering for the spring as well.
