Old 11-29-2023, 05:57 PM
dannystarr dannystarr is offline
Default Rally Wheel GM 15 X 7
This is a K-1-0 YH coded GM Rally Wheel Dated 3 9 70. Has 15 x 7 and JJ stamped on inside. Good condition but has some pitting. The pitting is around the inside bead where the tire would seal. I had a tire mounted on this rim for 3 or 4 years and it held air fine. But can’t guarantee it will hold air. May have to just run a tube. Lug holes showing some light wear. They have a very slight ridge at the top of each hole. You could leave it, I did. Or take a dremel and smooth them out. Really just normal wear. Paint is fair at best. I would strip, prime and repaint. $350 Plus S/I Sold as-is ... Danny
Attachments - The Supercar Registry 20231129_123204.jpg 20231129_123159.jpg 20231129_123151.jpg 20231129_123144.jpg
