Old 01-03-2024, 04:24 PM
dlv4540 dlv4540 is offline
Default 1960-69 283 302 327 350 396 427 SBC & BBC Parts & Engines
1960-62 #1110947 distributor $35
1962 #3782461 X heads both dated A-5-2 $1250
1963 327-300HP turbo fire engine complete from the air cleaner to the steel crank.
#3782870 standard bore block dated L-13-2 stamped J179687 F1217RB for a 327-300HP 4 speed block. Block has one quarter size hole in the middle of one cylinder requiring a sleeve. Can have fixed or you can have your machine shop repair it. I wanted the damage to be seen.
#3782461 X heads both dated L-15-2
#3797942 & 3797901 factory exhaust manifolds
#3844459 intake dated B-6-5 with factory AFB Carter carb shown as a factory service replacement intake from 1963-65
Steel Crankshaft uncut
Factory turbo fire valve covers
Factory air cleaner base and lid
Factory water pump with original pulley and has a aftermarket fan blade
Factory crank pulley
Factory timing cover
Factory original rods with seven pistons
Sell the whole engine for $3,000 or seperate out.
1957-65 Corvette 10.5 inch 168 tooth 4 speed flywheel. Price is $175
1968 327 long block
#3914678 standard bore block dated K-6-7 stamped T1109YC
#3917291 heads dated J-11-7 & J-12-7
#39411740 cast uncut crankshaft
Factory pistons and rods
$1,000 for the whole set up or will seperate out.
1969 #3927186 heads 2.02 valves dated I-18-8 & K-5-8 $900
1969 #3927186 heads 1.94 valves both dated D-2-9 $750
1969 #3927186 single head dated G-25-9 $350
1969 #3927186 heads both dated K-30-8 complete 2.02 heads $1250 rebuilt with about 10,000 miles on them
1969 #3927186 single dated K-2-8 with 2.02 valves $450
1969 #3927186 single head dated K-27-8 freshly rebuilt with 1.94 valves $600
Can ship and can provide pictures as well. A lot of the parts have been cleaned and magnufluxed or if needed can have done as well. Any questions 330-770-2517
9 additional items added to this listing these will be deduction from total available.
Dennis Vugrinovich
Last edited by Steve Shauger; 06-24-2024 at 11:10 PM. Reason: Updated # of additional for sale items in ad
Attachments - The Supercar Registry 20231212_153619.jpg 20231212_153452.jpg 20231212_152524.jpg 20231212_151601.jpg
Old 01-20-2024, 08:41 PM
#3927186 set dated K-30-8 are sold.
Will sell the K-2-8 & K-5-8 heads together as a set instead of the I-18-8 that came with the head.
Dennis Vugrinovich
Old 01-21-2024, 02:38 AM
3927186 heads dated D-2-9 and the single dated G-25-9 being dropped off at the machine shop to be cut out to 2.02 valves. Will update when finished.
Dennis Vugrinovich
Old 01-26-2024, 11:58 PM
Sale pending on 1968 327 engine.
Dennis Vugrinovich
Old 01-27-2024, 12:46 PM
Steve Shauger's Avatar
Administrator
Default Combining Sale Items in one ad
Dennis, you should know the rules. Here's a reminder:
https://www.yenko.net/forum/showthread.php?t=150432
You have at minimum 11 items listed. The 10 combined ads will be subtracted from your remaining balance. We have other option for high volume sellers.
Regards
www.yenko.net
www.vintagecertification.com
Old 01-27-2024, 02:37 PM
I did this so it would not take up a lot of room on the parts listing. I don't see why I should be punished for putting it all in one add? I have done this in the past and never heard anything about it?
Dennis Vugrinovich
Old 01-27-2024, 02:48 PM
Administrator
The rule has been in place for 5 years. Each ad is $1 so all the 11 items you posted =$11. I was informing you that you now have 19 ads remaining NOT 29. Punishment, no just notifying you and reinforcing the rules.
If you want to place multiple items in one ad, you need to become an advertiser. We spoke about a few years ago.
www.yenko.net
Old 01-27-2024, 02:55 PM
Don't remember that conversation but appreciate you going from 10 to 11.
Dennis Vugrinovich
Old 01-27-2024, 03:02 PM
Administrator
IIRC you were retiring at the time and things were in flux.
www.yenko.net
Old 01-27-2024, 04:51 PM
luzl78 luzl78 is offline
$30 for a membership. You pay that for 2-3 starbuck coffees
The Following User Says Thank You to luzl78 For This Useful Post:
Spike (05-06-2024)
