Old 04-05-2024, 12:04 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Fitting to run mechanical temperature gauge and dash light?
Trying to install a period correct mechanical S-W temperature gauge and still run the factory temp lights in the dash in a 62 409-409. As far as I can tell the temp sender location at the front of the factory 881 2x4 manifold is the only location to install a temperature sensor. Any suggestions to be able to do this or do I have to give up the dash lights in order to run the gauge?
Thanks
Jake Dykstra
Dykstra Motorsports
