Old 05-07-2024, 04:37 PM
Rumbleguts396 Rumbleguts396 is online now
Default 837 Alternator Stamp thoughts
Hey guys, what do you think of this 837 alternator stamp? Original? Does the 3 in the 1100837 look a little off ? Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 05-07-2024, 07:15 PM
mhm1966 mhm1966 is offline
The only known dates I have in June are 9F2 and 9F17 but there may be other dates.
The Following User Says Thank You to mhm1966 For This Useful Post:
Rumbleguts396 (05-07-2024)
Old 05-08-2024, 02:29 AM
dvss1 dvss1 is offline
The #7 in the 837 number is the wrong font.
The Following User Says Thank You to dvss1 For This Useful Post:
Rumbleguts396 (05-08-2024)
Old 05-08-2024, 02:40 AM
Rsconv68 Rsconv68 is online now
I’m no expert by any means, but I see the 37 definitely off compared to the many alternators I’ve seen. Even the ones at swap meets tossed in a pile have straight numbers. I’m curious what others think.
The Following User Says Thank You to Rsconv68 For This Useful Post:
Old 05-08-2024, 12:09 PM
William William is offline
Compares well with another stamping two weeks later.
The Following 2 Users Say Thank You to William For This Useful Post:
Charley Lillard (05-08-2024), Rumbleguts396 (05-08-2024)
Old 05-08-2024, 01:59 PM
The 7 in the 837 looks wrong to me. In addition to being a bit higher and crooked, it doesn’t have a squared off area in after the change from the horizontal to the vertical portion of the 7. If you compare that 7 to the 7 in the 37A on the same alternator, there is a difference.
Jason
The Following 5 Users Say Thank You to SuperNovaSS For This Useful Post:
BCreekDave (05-08-2024), BLACKLS5 (05-08-2024), olredalert (05-08-2024), Rumbleguts396 (05-08-2024), SS427 (05-08-2024)
Old 05-08-2024, 03:16 PM
Jason
The 7 in '837 is the one to watch out for. Many' more common '834's have been changed to '837's.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
Old 05-08-2024, 06:21 PM
the427king's Avatar
Restamp
No Fisher priced toys here
The Following 2 Users Say Thank You to the427king For This Useful Post:
big gear head (05-09-2024), Rumbleguts396 (05-08-2024)
Old 05-08-2024, 06:53 PM
John Brown's Avatar
I get wary any time I see a line that goes from left to right in the area near where the adjuster bolt boss is. That can be an indication that metal and numbers were removed. Some are more pronounced, but there does seem to be a little bit of a line showing up on this one.
John Brown
Old 05-08-2024, 06:58 PM
John Brown's Avatar
This appears to be the alternator in question.
https://www.ebay.com/itm/256503383527?
John Brown
