Old 05-23-2024, 02:30 AM
Default Casting date location on 69 435 vette intake manifold?
Where is the casting date located on a 69 vette 435 intake manifold? Is it under the bottom shield? Appreciate and help. The carburetors have a 69 date.
Attachments - The Supercar Registry Screenshot_20240522_222820_Gallery.jpg Screenshot_20240522_222713_Gallery.jpg IMG_5255.jpg IMG_5254.jpg
Old 05-23-2024, 02:46 AM
I believe it is located under the metal shield on the underside, pry up the push in rivets with a V shaped panel remover and a hammer to see it. You will not believe the caked on Crud underneath the shield and manifold. Good luck. Bill
The Following User Says Thank You to Big Block Bill For This Useful Post:
Jimlt4383 (05-24-2024)
Old 05-23-2024, 03:02 PM
As stated above, it is under the splash/heat shield on the underside. Attached are a couple pictures as an example.
Jason
The Following 2 Users Say Thank You to SuperNovaSS For This Useful Post:
dykstra (05-24-2024), Jimlt4383 (05-23-2024)
Old 05-23-2024, 04:47 PM
John Brown's Avatar
I have had good luck removing the splash pan rivets using a thin bladed screwdriver placed between the manifold and the shield. Place the screwdriver where it is just far enough off center from the rivet that it doesn't run into the rivet when tapping the screwdriver in. That ramps the rivet out with minimal damage. I normally reuse the rivets without needing anything in the holes.
John Brown
The Following 2 Users Say Thank You to John Brown For This Useful Post:
Jimlt4383 (05-23-2024), mssl72 (05-23-2024)
Old 05-24-2024, 01:58 AM
what is a pretty complete setup worth (69 435hp)
Old 05-24-2024, 11:35 AM
iluv69s iluv69s is offline
I’ve removed the rivets using vise grips with duct tape.
The Following User Says Thank You to iluv69s For This Useful Post:
