Old 05-27-2024, 04:29 AM
Default 68 - 72 GM A-body Deluxe Seat Belt Set
NO RESERVE!!! On eBay now for auction is a complete set of black Deluxe seat belts for a General Motors A-body coupe with bucket seats. They are dated for late in calendar year 1971, so undoubtedly originally came in a 1972 model car. If you aren’t concerned about the date codes, they could be used for the 1968 to 1971 models also. These would be correct for a Chevelle (including SS396 or SS454), Olds Cutlass or 442, Pontiac Tempest or GTO, Buick Skylark or Grand Sport. They may even be correct for a Monte Carlo or Grand Prix or other models, but do your homework before bidding. Everything you see in the pictures is included. The retractors for the outboard front seat lap belts work perfectly. There are belts for the two front seat occupants, including separate shoulder belts, as well as three lap belt sets for the rear seat passengers. One mounting bolt is missing from one of the roof-mounted shoulder belts, but the other three are present. Also included, but not pictured, are four mounting bolts. The belt material is very clean and pliable with no visible defects. The brushed metal female buckles are in excellent original condition. These have been kept in clean, dry storage in a non-smoking home in the 20+ years I have owned them. I think you would be hard pressed to find another set that is this complete, with matching date codes, and in such good original condition. Offered with a $9.99 minimum bid and NO RESERVE. No ‘Buy-It-Now’, the auction will run its duration. Thanks for looking, good luck and happy bidding!
See more pictures on the auction listing....
https://www.ebay.com/itm/266820250933
Bill Pritchard
