Old 06-15-2024, 06:03 PM
Kurt S Kurt S is offline
Default Complete 1969 Z28 drivetrain
Complete 1969 Z28 drivetrain with original DZ motor, M21 transmission, and 4.10 12-bolt axle. The drivetrain was removed several years ago from a running and driving Z28 that was converted into a pro-touring car.
Engine is V0414DZ, M21 is P9D14B, axle is BV0425G1.
The block is casting 6618, cast D89, original 186 heads (D39 and C289), 403 bellhousing, 7-blade fan, valve covers, driveshaft, and crossmember. It does not have the original intake, carb, or distributor and the car owner doesn't want the drivetrain back.
$11,000, located in southeastern Michigan.
Kurt S - CRG
Attachments - The Supercar Registry 2022-07-02 18.38.46.jpg 2022-07-02 18.28.12.jpg 2022-07-02 18.27.27.jpg 2022-07-02 18.21.51.jpg
