Hi guys,I've never changed the oil in the 12 bolt of my Camino.Would 2 quarts of 80w90 and a 4 oz.bottle of posi additive be enough?Thanks,Bill.
https://www.youtube.com/watch?v=gkDf7PPRzJ0 |
Yes, unless you spill some.
The Following User Says Thank You to big gear head For This Useful Post: | ||
bcmiller (07-06-2024) |
Big Gear Head............Could you list what options we have for POSI ADDITIVE ????
Chuck Sharin CamarosRus@gmail.com Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
The GM additive still works most of the time. The Ford additive seems to work better, if you don't mind putting Ford oil in your Chevy. Amsoil makes a good additive. I don't like the stuff that comes in a tube at the auto parts stores.
Don't spill it! You will have that unique smell in your shop/garage for weeks and it permeates everything!
I use only GM posi additive as I have had issues with anything else as far as clutch chatter.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
Draining the old, used oil, is the strongest and worst, smell and there is no way to avoid getting that smell in a building, unless it is drained outside. The new oil, almost, smells good, compared to the old "stuff"...
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
396 SS/RS (07-09-2024) |
I use the GM positraction axle gear lube in the old metal quart cans. I also use the limited slip differential fluid that comes in those small plastic containers. The old sperm whale fluid that is tuff to find these days.
I personally think it is better for the old original gears and posi plates. |
![]() Quote:
Barry Allan |
IIRC, all 12 bolt rear axles were not automatically a posi traction.
