Old 08-20-2024, 09:17 PM
Default Power Accessory Feed Wire
Up for sale today is a OEM power accessory feed wire for late 60s – early 70s Chevrolet products. This functions much the same as a multiple outlet power strip you undoubtedly have in your house. It plugs into your fuse block under the dashboard and then has three ‘outlets’ for connecting other circuits or accessories. Most likely uses would be for additional lighting such as inside rear view mirror map light, glove box light, console lights, trunk light, etc. I would bet that this is used on other makes and models of GM products of the same vintage, but do your homework before buying. I’ve looked and cannot find this item being reproduced by any of the major collector car reproduction wiring manufacturers; you can have this clean OEM piece being offered here for only $15.99. Thanks for looking!
Bill Pritchard
Attachments - The Supercar Registry 100_4327.jpg 100_4326.jpg 100_4325.jpg 100_4324.jpg
Old 08-21-2024, 02:07 AM
LT1vette LT1vette is online now
PM sent
