Old 09-21-2024, 07:09 PM
ALLZS ALLZS is online now
Default Timing chain r&r
need to replace the timing chain on a 68 camaro 302 should i pull the engine or try to do it in the car
Old 09-21-2024, 07:44 PM
luzl78 luzl78 is offline
In the car for sure.No new camshaft?
Old 09-21-2024, 09:08 PM
car is a unrestored survivor that still has the original nylon timing gear and chain car runs fine just dont trust the old 56 year old gear and chain . i thought it was a pain in the ass to just pull the pan in the car
Old 09-21-2024, 11:35 PM
Should be able to disconnect motor mounts and lift up and remove pan
Old 09-22-2024, 12:09 AM
I've never removed the pan with the engine still in the car. If you removed the transmission, bellhousing, clutch and flywheel it would be a lot easier to get the pan out. I have removed the timing chain cover without removing the pan, but if you don't want to damage the cover in any way then I wouldn't recommend that.
Old 09-22-2024, 12:11 AM
i want to pull the pan to get all the nylon chunks out of the pan and oil pump pickup screen
Old 09-22-2024, 04:36 AM
Then pull the engine and do a better job of getting it back together without leaks.
chevyman0429 (09-22-2024)
Old 09-22-2024, 05:59 AM
Rsconv68 Rsconv68 is offline
If you pull the engine, you can replace the rear seals and all the gaskets. And clean the engine bay while it’s out.
The Following 2 Users Say Thank You to Rsconv68 For This Useful Post:
396 SS/RS (09-23-2024), parkbrau (09-23-2024)
