Old 12-06-2024, 09:48 PM
Default Big Block VAlve Cover ID Help ?????
I have what I assume(d) was a matching set of OEM Big Block Valve Cover
One of the Yenko members offered me the below opinion.........
I'm now asking for YOUR 2nd Opinion as I feel that these two (L&R) covers
are a born together set from ??????? (Car Model/Engine/Year)
"That is not a matched pair of valve covers in my opinion. the passenger side is 100% for late 68-69 up for Camaro Chevelle Nova etc
The drivers side has the 2 small clips on top for a temp sending wire so it is not for a 68 or 69, it is for 67 IMO, but not correct for Camaro because of the top right plug wire stand. The temp sending wire for a 68 is not routed on the valve cover. It is definitely not correct for any Camaro Chevelle or Nova."
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Attachments - The Supercar Registry PXL_20241124_031428480.MP.jpg PXL_20241124_031233639.jpg PXL_20241124_024721538.jpg
Old 12-10-2024, 11:12 PM
To The Top
Chuck Sharin
[email protected]
Old 12-11-2024, 12:25 AM
William William is offline
http://www.camaros.org/engine.shtml#bbcover
Old 12-11-2024, 08:25 AM
69L78's Avatar
69L78 69L78 is offline
Chuck, This is exactly what I was trying to explain to you, go to the link & read about the changes in the LH valve cover because of the temperature sending wire. Also The top rear plug wire stand on either side of the top rear bolt hole is a big indicator of application.
