Old 12-13-2024, 12:02 AM
Dragin Dave Dragin Dave is offline
Default Exhaust manifold crack repair
Hello,
Who does cast iron exhaust manifold crack repair? Hoping for an invisible repair. I have heard there are guys that can repair and the cover up. Thanks in advance!
Old 12-13-2024, 03:54 AM
Tuna Joe Tuna Joe is offline
Lock-N-Stitch in Turlock, CA
World leaders in cast iron repair. None better.
Pioneered and patented the stitching technique (heatless repair)
I took a block in there to be repaired. It wasn’t cheap and took awhile but was invisible when done.
I saw a lot of exhaust manifolds in there being repaired.
Old 12-13-2024, 09:14 AM
69L78's Avatar
69L78 69L78 is offline
Jerry MacNeish also has a good source in Md., I had my 69 Z exhaust manifold repaired.
Old 12-13-2024, 11:43 AM
Good info,as I am looking also.
Old 12-13-2024, 12:42 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Rick -
About 15 years ago Dad had one of the 409 exhaust manifolds repaired in Chicago somewhere - I will see if I can find the location.......
Jake Dykstra
Dykstra Motorsports
Old 12-13-2024, 03:07 PM
Indy Cylinder Heads had an oven that they used to repair cast iron heads. They would weld the heads while in the oven at high temperature. I don't know if they still do this or not. Dale Meers Racing Engines in Buffalo KY has a guy who weld cast iron blocks for him.
Old 12-13-2024, 07:17 PM
Thank you for the responses. Happy Holidays everyone!
Old 12-13-2024, 11:23 PM
RPOLS3's Avatar
Originally Posted by RPOLS3 View Post
Rick -
Windy City Engineering Inc.
3244 W. 30th St.
Chicago IL 60623
773/254-8113
Jake Dykstra
Dykstra Motorsports
Old 12-13-2024, 11:25 PM
Thanks Jake.
RPOLS3 (12-14-2024)
Old 12-14-2024, 01:47 PM
mhm1966 mhm1966 is offline
There is a shop in New Jersey called Automotive Restorations. The owner is Steve Babinsky and he has cars that go out to Pebble Beach every year. I talked to him about cast iron welding a few years ago and he said you can't even buy a quality cast iron welding rod anymore. He has his own rods made up especially for him. The important thing when welding exhaust manifolds is to put them in a jig first before you start the repair process. (908) 236-6400 or [email protected]
