Old 01-02-2025, 06:26 PM
whitetop whitetop is offline
Default Early style Auto Meter gauges NOS lot with tach and cups
https://www.ebay.com/itm/335752900906
Old 01-02-2025, 06:27 PM
You are bidding on a complete set of first edition early to mid 70's Auto Meter 2 5/8 gauges, tach and cups. Perfect for your early Super Stock, Pro Stock restoration. or Day 2 street machine restoration.
NOS parts include all four 2 5/8 gauges and one cup. Rest are mint used.
These are the early 70's style with the "fat bezel" and correct early face markings without the words "Sport Comp". Later 70's had a thin narrow bezel and the words Sport Comp. These are all mechanical gauges. I tested the water temp gauge and it works-put the lead in boiling water.
4 mint cups (one is nos) with the very rare early style cast mounting base. Later style mounting bases were/are stamped steel.
Tach is 12 volt negative ground, 8 cylinder , 10k rpm so it fits just about every application. I have no way to test the tach but the guy I bought it from is fastidious about condition and said it worked fine. Needle bounces around as it should and returns to zero. No dents in the soft aluminum bezel which is really rare. Tach is from the late 60's to mid 70's era based upon the decal and face. Tach does not require any special sender.
Fuel pressure gauge does not have the safety warning printed on the face the newer ones had.
Free shipping to lower 48. Buying as is no returns.
