Old 01-08-2025, 09:24 PM
downunder1's Avatar
downunder1 downunder1 is offline
Default LS6 fan belts
I'm going to replace the fan belts on my LS6.
Can some tell me please what the Gates part #s are for these belts? or another quality brand would be okay.
I'm down in NZ and it can be difficult to source parts here.
Thanks in advance,
John
Old 01-09-2025, 01:32 AM
Rsconv68 Rsconv68 is offline
Year of car, cubic inch engine, transmission and engine options usually narrow down everything. Trying to look up a belt for the engine itself wont work.
Power steering? AC? Smog pump?
Old 01-09-2025, 04:45 AM
downunder1's Avatar
Obviously it's a 1970, 454 ci, power steering, no smog pump, AC on an LS6, I don't think so.
Thanks for your input.
Old 01-09-2025, 11:58 PM
Chevelle? El Camino? Transplanted engine into something else? The LS6 was also available in the Corvette in 1971 IIRC. I would think the A.I.M. would show the same belt for any other big block, but you would need to check.
Old 01-10-2025, 04:55 PM
----71 LS6 Corvettes had short water pumps so the belts would be different, I believe....Bill S
Old 01-10-2025, 06:46 PM
tunes's Avatar
tunes tunes is offline
Since his picture shows a 1970 Chevelle, I would assume that is the car he needs a belt for.
Robert
_______________
2023 Stingray Coupe Z51
The Following User Says Thank You to tunes For This Useful Post:
downunder1 (01-11-2025)
Old 01-10-2025, 07:00 PM
Yes, it's for a 1970 LS6 Chevelle. Rick Nelson you out there?
Old 01-10-2025, 07:47 PM
Hi John,how's your Summer going?
Sounds like you want a Big Block 1970 Alternator belt AND w/o SMOG too,as it wraps around just the crank,water pump and alternator pulley only.Original Part# for that is #3937789 & can be used on ALL 1970 LS-3,L-34,LS-5,L-78,LS-6 applications W/O SMOG.
Quanta sells this GM Restoration/factory correct looking belt as Part# 29B-602,but cross reference with other MFRs.that might have a different look.And I recommend whomever you buy from,call and ask them to confirm the overall length with you first before ordering,as they measure out at just over 46 inches with Deepgroove pulleys when on the car,(at least mine do when stretched.)
Anything longer is a Big Block SMOG PUMP (YE) Belt.
And Power Steering as you know is a separate belt run by the crank pulley only,and not powered by the Alt. belt.
Old 01-10-2025, 11:46 PM
Fortunately Chevrolet used a lot of the same belts across the production line and Quanta carrys alot of them. One of the belts for my 6 cylinder is also used on a Corvette, so there should be no issue finding the correct fitment for the big block.
Old 01-11-2025, 04:08 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Default fan belt size
Here are some sizes from GM parts catalogue that might help. 9782707 power steering belt, 3937790 fan and alternator, no listing for air pump.
The Following 2 Users Say Thank You to MarcDant For This Useful Post:
downunder1 (01-11-2025), dykstra (01-12-2025)
