Old 02-06-2025, 02:24 AM
69W314spd 69W314spd is offline
Default 1969 nova questions
I've Recently purchased a 69 nova 4 speed car that i believe was a big block four speed car and possibly and L78 originally.
69 69 cortez silver 731 interior, no gauges
Some identifiers the car has are as follows
Correct big block core support
Correct cross member
Single 3/8th fuel line (11427 car not a 6cyl as they also came with single fuel line no return)
ZD code radiator (big block 4sp Radiator)
Correct power brake booster and 69 calipers with single groove rotors which i believe to be correct.
BS Code 12 bolt (3.31 posi) 1207G1 date
Correct heater box outlet.
837 Alt with 8m19 date code Car is April built
block and transmission are out of a 1966 Chevelle EF code (360hp 4 speed)
No paperwork, car was sold new at oaklanddon Chevrolet in Indianapolis according to ncrs and its official build date was 4/16/1969.
My question is about the driveshaft stripe color, i believe that the drive shaft is original to the car and has what i believe to be an orange, blue and white stripe and was curious of what this could mean as i dont have build sheet.
Pics attached
The Following 14 Users Say Thank You to 69W314spd For This Useful Post:
69M22Z (02-06-2025), big gear head (02-06-2025), dykstra (02-07-2025), gtomike1967 (02-06-2025), L78_Nova (02-06-2025), ls6owner (02-06-2025), markinnaples (02-06-2025), napa68 (02-06-2025), olredalert (02-06-2025), PeteLeathersac (02-06-2025), racerkvn (02-06-2025), Stihl (02-22-2025), Tenney (02-07-2025), Zman1969 (02-14-2025)
Attachments - The Supercar Registry Prop shaft chart sample.JPG Nova HMM 2.jpg IMG_6461.jpg IMG_4306.jpg
Old 02-06-2025, 01:39 PM
racerkvn racerkvn is offline
That's a good looking Nova
Old 02-06-2025, 02:07 PM
napa68 napa68 is online now
This^^^^^
Old 02-06-2025, 03:07 PM
Very nice Nova you have. Check the date code on those rotors, 69 Novas should have the two-piece style rotors. The reason I say this is, I have a Jan. built 70 BB Nova that still retains the original two-piece rotors. I believe they started the one-piece rotors during later production of 1970. Love the color, keep the pics coming.
Old 02-06-2025, 05:24 PM
Keith Seymore's Avatar
Maybe you already know this, based on your question, but the stripes correspond to the part number for this specific application.
Each of the various driveshaft part numbers would have a different stripe color or configuration in order for the installer to quickly identify the right part, as called out on the build sheet. The stripe colors were used in lieu of a broadcast/pick code. You may recognize Broadcast/pick codes as used on other components like engines (ie, "TAB or TAC", etc), transmissions, rear axles, radiators; Any place where there was quite a bit of part number proliferation.
I do not know the specific part number your colors represent, if that is what you are asking.
I do have one page of a chart for Chevy pickups, to give you a flavor of what the part release looks like (attached).
The stripes were added by the component supplier (Parma, or Dana, or whomever) right after balancing. While the part was still chucked up it was turned by hand and the brush held near enough to slop some paint on the tube.
K
'63 LeMans Convertible
'63 Grand Prix
The Following 3 Users Say Thank You to Keith Seymore For This Useful Post:
dykstra (02-07-2025), olredalert (02-06-2025), Tenney (02-07-2025)
Old 02-07-2025, 12:25 AM
the car does retain its two piece rotors
Old 02-07-2025, 12:27 AM
Again - I apologize if I am telling you something you already know (and not telling you what it is you wanted to know).
K
this is great info and helpful as i come from Oldsmobile's so alot of this is new.
The Following User Says Thank You to 69W314spd For This Useful Post:
Keith Seymore (02-07-2025)
Old 02-07-2025, 01:35 PM
I see now that the driver side has a two-piece rotor, and the passenger side has the one-piece. If you still have the other two-piece rotor and is in good shape, I would reinstall it.
Old 02-14-2025, 12:32 PM
Zman1969 Zman1969 is offline
I'd be on hunt for a L78
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 02-16-2025, 01:46 PM
JRSully JRSully is offline
The default rear gear for an L78 was BT (3:55) and the L34 was BS (3:31) although anything could be ordered. Single fuel line is interesting though... Believe there are some L34's that may have come through with single fuel lines, may be wrong on that
71 Porsche 911 Targa
