Old 02-21-2025, 02:40 PM
mhm1966 mhm1966 is offline
Default NOS Service Rack Kit
GM #7844651 service rack kit. Kit includes ignition rack, ignition switch gear, locking pin spring with screw, upper bearing with race, and lower bearing. $40 plus shipping.
1966 Corvette Coupe L79 Mossport Green
1969 Camaro Z/28 Hugger Orange
NCRS #22211
Attachments - The Supercar Registry PXL_20250220_170653773.MP.jpg PXL_20250220_170353024.jpg IMG_0404.JPG
Old 02-22-2025, 01:23 AM
70post 70post is offline
Can you tell how many "small" teeth are on the black plastic gear inside the bag....see PIC below for what I'm referring to.
Thanks
Patton Glade
70Post Restorations
Austin, TX
Old 02-22-2025, 02:31 PM
The same amount in your picture 5 teeth total.
NCRS #22211
Old 02-28-2025, 12:47 AM
I think I may need a piece w/more teeth. I need to do some more digging here to see if I have another one I can verify the tooth count on. In the meantime, if someone else wants this have at it. I need to check a couple other Olds columns here first.
Thank you.
Patton Glade
70Post Restorations
Austin, TX
