Old 03-05-2025, 05:57 PM
seventyLs5 seventyLs5 is offline
Default Muncie 4 speed from Lemans?
Picked up a Muncie 4 speed over the weekend and the guy said it was from a 67 Lemans with a 326 2 barrel. It still had the tag on the side cover and from research it comes back as 67 GTO wide ratio. Was the 326 available with the Muncie 4 speed? I know in the Chevelles that the base V8 got a saginaw 4 speed but not sure on Pontiac.
Attachments - The Supercar Registry muncie1.jpg muncie.jpg 20181020132531-b8891be1a.jpg
Old 03-05-2025, 06:30 PM
grantprix's Avatar
Yes, also available in the LeMans, same M20 wide ratio transmission as GTO.
The Following 4 Users Say Thank You to grantprix For This Useful Post:
60sStuff (03-09-2025), olredalert (03-05-2025), PeteLeathersac (03-05-2025), Tenney (03-11-2025)
Old 03-09-2025, 08:03 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
So they did use the term “Power Train” (Engine, Transmission, Axle). WDYK …..
The Following 2 Users Say Thank You to 60sStuff For This Useful Post:
grantprix (03-10-2025), olredalert (03-09-2025)
