Old 03-25-2025, 12:54 AM
Smile Huge C3 Corvette Parts List (Mint Top Flight Pieces!)
1971 Corvette Parts For Sale
Backstory: As some on this forum know, I have a very nice Top Flight 1971 small block coupe, but I long for the 1971 LS6 car I owned up until early 1975. I can’t afford a nice LS6, hence my (difficult) decision to build a loose non-matching number clone. The Corvette in question Top Flighted in 2011 (score of 99.6) and as I understand it, shortly thereafter, was placed in a plastic bubble and stored in the original owner’s heated, air conditioned basement. Parts removed from the car are absolutely pristine and beautifully detailed. What follows is an initial list. I will have more bits and pieces available as I progress. Parts are located in Delisle, SK, Canada (North of Montana). Aside from exhaust system, wheels, fan shroud and perhaps the bellhousing, they’re all easily shipped by way of the post office. Feel free to contact me for more info and photos. Prices in US Dollars.
1. Air cleaner assembly. Complete, less element. Fits 1971 350-270 and I believe 454-365. $500
2. Small block alternator brace (lower). Original. $75
3. Small block exhaust hanger bracket, center. $25
4. Small block fan belts (No Air Conditioning or Power Steering). Original. $50
5. Small block metal fan shroud, complete. $300
6. Small block front stabilizer bar (includes rubber bushings). Original. $125
7. Small block upper and lower radiator hoses. $50
8. Small block starter brace. Original. $10
9. Small block water pump, 3991399. 375
10. Muncie Shifter, complete with mount bracket assembly. $300
11. Shocks, non F41, Complete detailed set from my flight judged car. Front 3192196 with 253-70 Date Code. Rear 3192869 with 227-70 Date Code. Function normally (no leaks). $1400
12. Small block ignition shielding, complete set. $350
13. Exhaust system, complete from head pipes to exhaust tips, as new with proper crimping and “flattened” sections. Beautifully detailed. Base engine 4 speed. $750
14. Small block starter, complete. Part Number 1108338. Date Code: 1A5. $300
15. SOLD! 1971 Original wheels & original Firestone Wide Oval Tires (set of four). Wheels repainted and detailed (car was flight judged by a previous and original owner). K-1-0-10 14AZ codes & bead dots. F70X15 nylon cord Firestone "super sport" Wide Ovals (9 rib tread) -- all DOT. No evidence of sidewall cracking. Tread depth ranges from 0.255-inch to 0.290-inch. $1500 + Shipping. SOLD!!!
16. Chevy 3899621 Bellhousing. Beautifully restored original GM production 11-inch 621 bellhousing. $300
17. SOLD! Bellhousing dust cover and hardware. Original production line. $25….SOLD!
18. Harrison 3155316 Aluminum Radiator. Fits 1965-72 small block Corvettes (non-AC). Used but appears as new. Fabulous piece with 70K date code (rad built in October 1970). $1,000.
19. Radiator support. Original production for small block, non-AC car with aluminum radiator. No damage. No rust. Detailed. Appears as new. $400
20. Chevrolet 3858533 BJ deep double groove crankshaft pulley. Small block applications (Corvette, L79, early Z/28 and others). Detailed and mint. $200
21. Fuel pump to carb line. Small block Corvette with Quadrajet Carburetor. $25
22. Exhaust manifold set. 3846559A (LH) and 3989036 (RH). Original GM. No AIR holes. Beautifully detailed. As new. $500
23. Rochester Quadrajet, 350 with Manual transmission# 7041213; DM 0071. $850
24. SOLD! Delco 115270 BR coil. Original “270 BR” production line part. Tests at: 1.9-2.0 ohms across the posts; 10,680 tower to positive. $400…SOLD!
25. AC R-44TS Acniter II spark plugs. GM part number 5613302. Correct production line spark plugs with correct original script (as well as script location) and correct markings for 1971. Brand new in the original package. $300
26. Carter mechanical fuel pump. Used. Nice condition. $30
27. GM Packard small block ignition wire set, dated 3Q70. Original GM. Nice shape. $250
28. Corvette Non-F41 rear spring. Beautifully detailed with new liners. $300
29. C2-C3 Corvette camber adjustment rods. Includes camber adjusters and other hardware. Beautifully restored original set. $120.
30. Original PF 25 oil filter in box. Correct late 1970-71 production line filter. New in original package. Price: ???
31. AC A 329-C Air Filter element. Correct square mesh and “PROTECT YOUR ENGINE – REPLACE WITH AC TUPE A329C” lettering. Looks NOS but was used for judging. Price: ???
Old 04-01-2025, 06:00 PM
Ignition shielding has been SOLD!
Muncie Shifter has been SOLD!
Starter Brace has been SOLD! (can't edit the original copy).
Old 06-02-2025, 03:52 PM
Rear Spring has been SOLD!
