Old 03-29-2025, 11:35 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Default Sagging sun visor
My right side visor sags down about half way and won’t stay up. Pulled it apart and it has some tape looking stuff around the rod. What is that? Looks like double sided tape.
What’s the fix to make it stay up?
Thanks,
Richard
1967 Camaro SS 396/375 4K
Old 03-29-2025, 11:41 PM
scuncio scuncio is online now
Pretty sure there should be a nylon sleeve there.
Old 03-30-2025, 01:05 AM
Yup.
Old 03-30-2025, 01:54 AM
1967 4K's Avatar
It’s there in one of the pictures. That’s not where it’s giving it’s where the rod goes into the visor.
Richard
Old 03-30-2025, 03:39 AM
There should be a metal sleeve in the visor to pinch the rod enough to hold it in place. You may need to carefully compress the sleeve together more to get the friction needed.
1967 4K (03-30-2025), 67SS4spd (03-30-2025)
Old 03-30-2025, 11:09 AM
1967 4K's Avatar
I see the sleeve thing inside the visor , I had thought about squeezing it somehow without damaging the visor material. Channel locks with rags between the jaws might work.
Thanks all,
Richard
Old 03-30-2025, 11:14 AM
67SS4spd's Avatar
67SS4spd 67SS4spd is offline
Yenko Premier Member
^^^^^. I used a piece of card stock to protect the visor and regular pliers to pinch the metal sleeve just eve so lightly. Worked perfect
Steve
67 Chevelle SS
