Old 04-11-2025, 08:37 PM
enio45 enio45 is offline
Default Parts Cleaner - cleaner fluid recommendation
What do you all recomend for a good cleaning fluid for a small size parts cleaner? I see a variety of brands etc, need to order 5 -10 gallons worth.
appreciate the advise
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-11-2025, 10:18 PM
hogdaddy hogdaddy is offline
Gool old mineral spirits works.
67 Convertible T-1
Old 04-11-2025, 10:34 PM
I agree with Mineral Spirits. I've tried a few of the non-toxic, environmentally friendly products but they just don't work nearly as well. Some will come close, given enough time to soak, but if you want greasy, dirty parts clean in a reasonable time, its MS. It will leave a slightly oily film when dry, which helps protect bare metal but if you are going to paint, the parts will need to be cleaned with Dawn and/or a good, solvent based, wax and grease remover.
Old 04-12-2025, 02:17 AM
bdk1976 bdk1976 is offline
I use Crown PSC 1000 from Tractor Supply - comes in 5 gallon cans
Old 04-12-2025, 02:31 AM
Ive heard good things on the Crown PSC 1000
They are around the corner from me - ill give that a try
thanks for the responses
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-12-2025, 03:23 AM
I wasn't aware of that Crown PSC, but it's about half the cost of 5 gallons of mineral spirits now. If it works as well, it's a better solution.
Old 04-12-2025, 04:16 AM
JMB JMB is offline
Super S Solvent 140
Currently owned:
1970 El Camino SS 454/M22 LS-5
1988 Monte Carlo SS LS7/T56 (700+ NA RWHP!)
2011 Corvette Z06 all stock
Previous owner of:
1970 Chevelle SS 454/M22 w/XCH crate LS-7
1970 El Camino SS 454/M22 LS-6
1970 Camaro Z-28/M22
Old 04-12-2025, 10:19 AM
1967 4K's Avatar
1967 4K 1967 4K is offline
I’ve used Crown cleaner for years, good stuff. Made in the town just north of me. I thought it was sold exclusively at Walmart but guess I’m wrong.
Richard
1967 Camaro SS 396/375 4K
The Following User Says Thank You to 1967 4K For This Useful Post:
enio45 (04-14-2025)
