Old 05-20-2025, 05:20 PM
BLACKLS5 BLACKLS5 is offline
Default 1968 Corvette transistorized ignition question.
Does the T.I. system not use the cloth covered resistor wire to the +side of the coil? The illustration on line looks like it doesn't but has a separate white wire coming from the T.I. box. I tried firing it up for the first time and it seems like it wants to start after you stop cranking and return to the run position. I put an HEI in it and it started right up. Is there in fact a separate wire that goes to the positive side of the coil instead of the resistor wire?
Attachments - The Supercar Registry K66 bypass.png 66_71_ti_diagnosis_chart_bbfd39c9c9067d37b5a75c496079de7824912a6e.jpg
Old 05-20-2025, 05:49 PM
William William is offline
The K66 ignition needs constant 12v supply. The resistor wire is bypassed.
Here's how it was configured for a Camaro. Since it was a Corvette option, there must have been a dedicated harness for it.
Old 05-20-2025, 06:00 PM
napa68 napa68 is offline
Does this help?
http://tispecialty.com/print/2.pdf
Old 05-20-2025, 06:50 PM
Originally Posted by napa68 View Post
Yes, That's the illustration I was referring to. I don't see any cut or spliced wires anywhere but I also don't see the white wire that goes to the coil. I'll do some more digging. I had the resistor wire going to the coil so I'm sure that's why it wouldn't start. Thanks
Old 05-20-2025, 07:50 PM
Let's throw this in for good measure......
The Following 5 Users Say Thank You to napa68 For This Useful Post:
dykstra (05-20-2025), earntaz (05-21-2025), L_e_e (05-20-2025), RobR (05-21-2025), RPOLS3 (05-21-2025)
Old 05-21-2025, 11:37 AM
Thank you Sir.
Old 05-21-2025, 03:02 PM
Tuna Joe Tuna Joe is online now
I’ll also add that if your battery isn’t fully charged it will not start.
The Following User Says Thank You to Tuna Joe For This Useful Post:
BLACKLS5 (05-23-2025)
Old 06-06-2025, 05:57 PM
BlackLS5, Would you please contact Chuck Sharin at Tu 5 Three, Tu 6 Three, 5 One Nine 0
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
