Old 05-31-2025, 12:03 AM
Default Priming an LS motor; new build
Rigged up a priming system using some old schedule 80 pvc that I already had on hand. The only piece I had to buy was an end cap to glue on. Had all the hardware on hand. Even had a small regulator already attached to air hose.
Found multiple videos on line.
Ran about 5 quarts through the priming port while slowly rotating the engine. Got oil to squirt up through every pushrod except #1 intake and exhaust.
Can anyone tell me if that is normal. I am fine running more oil through it and rotating until I get oil up through those two. Just didn't know if it was normal for some to take much longer than others.
Pro Stock John (06-03-2025)
Old 06-03-2025, 02:50 AM
Update. Had no time over the weekend, so went down to the shop this evening after work. My pressurized reservoir only holds about 2.5 quarts. I anticipated draining the oil and refilling it a couple of times. Probably refilled it at least 10 to 12 times before I was done.
Took almost another hour of running oil into the priming port (varied from 20 psi to 40 psi). I wasn't sure if increased pressure would help. But, I can guarantee 2.5 quarts runs through a lot FASTER at 40 psi.
Kept thinking I would get some oil on those two. Finally got oil on #1 intake after about 45 minutes. Had to run another 7.5 quarts through to get oil to the exhaust rocker.
At least that part of this job is done.
kwhizz (06-03-2025)
Old 06-05-2025, 07:57 PM
Pro Stock John's Avatar
Engine will still be a bit noisy on startup, but it will settle down. I assume you are dropping in a bone stock engine so there was no need to measure preload for pushrod length.
Old 06-06-2025, 07:21 PM
Correct. Reman long block.
Old 06-07-2025, 05:11 AM
Started on the first try. Not even one tick. Runs perfectly smooth.
The Following 3 Users Say Thank You to Lynn For This Useful Post:
67Ss4spd (06-07-2025), dykstra (06-09-2025), Pro Stock John (06-09-2025)
