Old 06-11-2025, 12:57 AM
lbnaz lbnaz is offline
Yenko Premier Member
Default Muncie M22 CT9
I am selling a 1969 Muncie M22 that started life as an over the counter (CT9) transmission. It was completely rebuilt about 7 years ago by Mike Gibbons a well-known SYC sponsor. I met him at Hot August Nights in Reno. I have spoken to him and asked for his permission to use his name. The case, tailshaft, and side cover still retain its factory sheen and finish. No blasting was done just a good cleaning to them. The input and cluster are original to the case. There was minimal to almost no wear to either gear. The 3rd gear is a reconditioned GM gear Mike had with almost no wear. The reverse gears are original GM again almost no wear. First, second, and fourth are new Perfection American Gear Co USA made gears. The reverse idler is GM nos. The slider sleeves are from Paul Cangialosi with the grooves in them for oiling. This was built for a project that went a different direction. It has never been installed, ran, or had oil in it just stored on a shelf in my garage. This is as close to NOS 1969 M22 you will find. The price is 3500 cash or personnel check. I will crate it up in a wooden crate made for 4 speeds by Auto Gear. I will deliver to your shipper that you arrange. I can also look into shipping quotes at local carriers. Larry 5203492337
The Following User Says Thank You to lbnaz For This Useful Post:
cruiserofland (06-11-2025)
Attachments - The Supercar Registry IMG_3675.jpg IMG_3674.jpg IMG_3673.jpg IMG_3672.jpg
