Old 07-16-2025, 12:30 AM
Default 1969 4346 Holley dated dated 912
Very early take-off from a L78 chevelle. Car was last registered in '74, sat disassembled with parts in trunk, including this carb.
It has very good color still. Correct blocks, bowls and baseplate. Main body has the 2 holes drilled in the choke horn as seen. Missing primary throttle blades and choke plate and shaft. The choke linkage is also missing. I may be able to help with that, but those parts are readily available. 5583 and 4519 metering plates.
This was sitting with a rebuild kit that looked as if it had been purchased 50 years back also. It'll be included but has the crappy paper gaskets and the power valves are a bit ugly looking.
Asking $400 paypal F and F.
Attachments - The Supercar Registry IMG_20250715_143228.jpg IMG_20250715_143006.jpg IMG_20250715_142709.jpg IMG_20250715_142651.jpg
