Old 02-26-2001, 07:46 PM
Chevy454 Chevy454 is offline
Default L-72 Dyno Test
I was just thumbing thru my MCR and noticed the dyno test they did on one of Peter Simpson's COPO engines...what are everyone's thoughts on the outcome?
I was surprised to see that changing the valve lash changed the torque amount the way that it did. That is one of the things that I have began to mess with more and more in the past year or so, and according to that article, my "lashing" is justified!
Old 02-27-2001, 12:06 AM
Belair62 Belair62 is offline
Default Re: L-72 Dyno Test
I was surprised to see the engine needed carb spacers to get close to the advertised HP figure. I think they wound up with a 2inch spacer.
Old 02-27-2001, 12:30 AM
COPO COPO is offline
That surprised me too and was a bit disappointing. The LS-6 they tested came right in at the factory rating of 450 hp, so I expected the same from the L-72.
I can tell "seat of the pants" that the valve lash makes a difference, I too was surprised it was that large.
Old 02-27-2001, 02:38 PM
JoeC JoeC is offline
The article states that they experimented with total timing from 36 deg to 44 deg and the dyno numbers did not change significantly. I would think that an 8 deg change in total timing would have shown some differance.
Old 02-27-2001, 09:53 PM
I was surprised that the engine made advertised horsepower with the stock exhaust manifolds. These pieces were a bottle neck. The value of fine tuning was also quite obvious. It would be interesting to see a run on the engine with headers. You aren't going to be driving on 112 octane gas all the time so how would the engine run on 92? As for the 2" spacer, it is not going to fit under a stock '69 Chevelle hood. The breather almost touches now.
[Edited by Keith Tedford (02-27-2001 at 04:53 PM).]
Old 04-14-2001, 10:09 PM
Sorry to drag up an old thread but I found some of the comments very interesting on this topic. The motor did make 420 honest horse without any spacers and before fooling with the lash. All dyno's are different, they are not calibrated like scales and federally watched. When my engine builder asked what dyno I wanted to use, he asked if I wanted to use a happy dyno or a sad dyno. The happy one would show 20 more horse he said. We chose the sad dyno because like he said, "when you have 420 horse, you know it's a true 420 horse. Depending on altitide, temp, and dyno, your results can be + or - 15 horse. The dyno is simply a tool for measuring changes which it does well. So while the paper out of the dyno is very interesting, the piece of paper that matters is the one at the end of the return road. That piece of paper said 12.69 @ 110 which was on F70-14 polyglas with a stock GM converter, and a single cross flow muffler. Also no spacer was used. The 454 MCR dyno'd did not have a stock GM cam and was run with 2" headers not manifolds. Have a great day and sorry to bring up an old thread but I'm new around here.
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 04-16-2001, 01:42 PM
YENKO DEUCE REGISTRY's Avatar
Pete;
I agree with you, the real power number is on the E.T. slip not the dyno printout. Impressive numbers at the drags from a stocker, congrats.
When will we see the COPO Nova run again?
Marlin
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 04-17-2001, 12:34 AM
Marlin! Man, I hav'nt seen you forever! Did you get your Yenko done yet. Remember put the stock cam in, ask Niel about that advice.The COPO will be out sometime but I'm not sure when. Hope to see you this Sept. and once again I'll bring the beer.
Owen Simpson
Eric Simpson
Old 04-17-2001, 02:30 PM
Pete;
My car is coming along, I hope to have it ready for the new All GM Show at Carlisle in June, 2001. I put the right cam in it, and the 11.0:1's, hope to hear it running by early next month. Some pics are attached, I plan on running whitewalls at the concourse shows. I only have two of the Atlas wheels, and am looking for another pair - anyone??
M
Marlin
Old 04-17-2001, 03:24 PM
M:
Car looks good! If you could get the car to look like that on the launch, you would have one heck of a 60 foot time! What a launch . Any chance of you making to Michigan this year? Is Neil gonna be there again?
Peter:
I'm hoping to rebuild my engine and see if I can get some dyno time to break it in a try a few things. Question: I need to curve my distributor...how soon does it need to be all in? 2,500? Sooner? Later?
