Old 02-28-2002, 12:22 PM
jon rand jon rand is offline
Default muncie shifter
what do i need to do to change a hurst shifter from a Super T10 to M21? It looks like it would work if I changed the levers and backing plate.
Old 02-28-2002, 04:43 PM
shor shor is offline
Default Re: muncie shifter
A good Question....Stefano? care to help?
Old 03-03-2002, 08:00 PM
Stefano Stefano is offline
Shor,
We were going from an after market Hurst Comp plus back to a factory original. The rods on the non original shifter were beefier and the shifter was mounted a couple of inches forward and used a different mounting bracket.
I regularly swapped T-10s for Muncies back when correct wasn't a concern and I was always able to get everything lined up without cutting the tunnel, But I do not remember the sequence of which parts to use.
Old 03-03-2002, 11:42 PM
Belair62 Belair62 is offline
Give Hurst a call and get the install kit...as long as you have the shifter part# I'm sure they can get you one in a day or 2.
Old 03-04-2002, 03:08 AM
69L89396 69L89396 is offline
Stefano,
Will the aftermarket shifter bracket work for the orginal shifter and linkage? I talking about Hurst comp shifters on a 69 Camaro with a Muncie.
[Edited by 69L89396 (03-03-2002 at 10:08 PM).]
Old 03-04-2002, 03:56 AM
It is my opinion that with the after market mounting plate the original Rods will be too long in standard form, but not certain.
I would try calling Hurst like Belair62 recommended.
Click to visit the Nickey Performance Facebook--&gt;
Old 03-05-2002, 05:27 AM
Thanks guys mabey i'll call Hurst. Once I get the shifter installed and drive shaft I can BLAST this Motion Camaro down the road. I cant wait HeHeHeHeHe...
