Old 06-10-2003, 10:14 AM
HuggerSS396 HuggerSS396 is offline
Default 69 Camaro no X code
I recently purchased a 69 Camaro. I only paid 3000 dollars for it. The car has SS trim with a 1972 Corvette 350 engine. It has a SS hood Power disc brakes a Th400 trans and a 12 bolt rear end. The car has a speedometer fuel gauge, column mounted tach, under dash oil batt temp gauge. Since this car does not have an X code and i could not find a broadcast sheet how can i verify that the car is an ss or even possibly a big block car.
VIN 124379N686813
ST 69 12437 NOR115132
TR 711 72B
09B
Thanks [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Old 06-10-2003, 11:44 AM
drdave69 drdave69 is offline
Default Re: 69 Camaro no X code
Are you sure about the VIN starting with N6xxxxx? It looks like the 09B and body number will be a September 1968 build. There aren't any X-codes until early to mid December 1968.
Dave
1987 Grand National
Old 06-10-2003, 11:48 AM
Yeah the VIN is 124379N686813 I just double checked.
Thanks
Old 06-10-2003, 01:15 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I just replied to this in the Tech section. Looks like the cowl tag was changed out. Do you have a picture of this tag??
Old 06-10-2003, 01:24 PM
I will take a picture and post it this afternoon. What do you think could have happened. The car looks really straight and the sheetmetal seems to be all original from my best guess.
