Old 10-06-2003, 01:13 AM
John's Avatar
John John is offline
Default minilite wheels
I ran across a set of ( 4 ) aluminium ...or magnesium wheels that look like the ones I have seen on the "Penske" trans am camaro..I believe the are 15" x 10"...5 lug chevy pattern...does anyone know what they went on? [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Attachments - The Supercar Registry 57941-69 mitch lambert.jpg 57748-AMX No2 The Ring 79.JPG 52711-Mvc-045f.jpg 52709-Mvc-044f.jpg
Old 10-06-2003, 03:29 AM
hvychev hvychev is offline
Default Re: minilite wheels
Jeff H whwre are you??? This is your bag baby!
Frank Magallon
Old 10-06-2003, 12:38 PM
Jeff H Jeff H is offline
If they are the GM 5 on 4-3/4" bolt pattern then I guess they could be for a Camaro. But I'm not sure if you can fit the 15x10 wheels without some wheel opening modification. I'll have to search through the articles on Penske's car because I think he cheated on the wheel size. Do you have any pictures of the wheels? The new aluminum version is slightly different from the original magnesium wheels. I've got the new heat treated aluminum wheels.
Old 10-06-2003, 03:53 PM
John's Avatar
..I WILL GET SOME PHOTOS AND POST THEM....
Old 10-06-2003, 04:09 PM
redvetracr redvetracr is offline
"Vintage" Minilite wheels (5x4-3/4) were used on both Camaro and Corvette race cars the old ones were magnesium and probably 8.5 or 9.5 wide. BEWARE 30 year old magnesium is unsafe as mag (when it gets old) is brittle and prone to crack. They are quite valuable though.
...redvetracr
Old 10-06-2003, 05:49 PM
John's Avatar
I took the rims to get the tires removed and got some photos and correct measurements...I originally was told they were 10" wide ...but I understand that the measurement in taken "from inside of rim...to the inside of the same rim"....so I do not believe these to be 10" wide..but 8.5" wide....see photos
...also I think these are "aluminium" and not magnesium.
...and the holes are tappered for the lug nuts to fit.
I am posting photos of each wheel.
Old 10-06-2003, 05:52 PM
John's Avatar
another photo
Old 10-06-2003, 05:54 PM
John's Avatar
third wheel
Old 10-06-2003, 05:56 PM
John's Avatar
...oops....third wheel
Old 10-06-2003, 05:59 PM
John's Avatar
..fourth wheel
