Old 10-25-2003, 03:17 PM
Zedder's Avatar
Zedder Zedder is offline
Default 1967 Z-28 Parts Wanted
Looking for '67 Z-28 parts: 266 distributors, DF wheels, 610 intakes, cowl plenum air cleaners, 6764 and 822 cranks, MO and MP blocks, etc. Thanks! [img]/ubbthreads/images/graemlins/[/img]
Mark
Old 11-10-2003, 11:53 AM
TDW TDW is offline
Default Re: 1967 Z-28 Parts Wanted
Mark...There is a NOS crank on ebay today. Says it is a 67 Z28.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 11-10-2003, 12:55 PM
Zedder's Avatar
Thanks Tony...I'll check that out!
Mark
Old 11-10-2003, 06:11 PM
Mark, You should be able to use a nice 283 crank. They are steel and small journal. Good Luck! Sam
Old 11-10-2003, 07:12 PM
68z302 68z302 is offline
Sam,
Although the 283 crank will fit it all depend how picky you are about your resto.
The bolting flange for the flywheel is different on a 302 VS a 283 crank. I can't remember which is which one has a bolting flange that is a full circle, the other has a notch in it. Plus the Z28 crank is tuffrided.
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 11-10-2003, 07:50 PM
Rob, You are correct. They were tufftrided. Most off that wears off in time. I never really saw a 302 or LT1 crank where that really mattered. I believe that the 1967 302 crank is a circle with a V cut into it. Anyhow it would all work. There are a couple cranks on e-bay and also I think there is a harmonic balancer available where the key way does line up with the timing mark. The block can be a 4 in bore job with small journals, or you can buy bearing spacers if a small journal is not available. To me the internal parts arn't as important to a resto. as the bolt on parts, as long as it is a REAL 302 with the correct compression. I was hard pressed to get 30 over pistons for my 1969 Z. We had to fly cut a set of TRW 12:1's. There are manufactures out there: Venolia, C+P etc, but are around $800.00 a set. (forged) Correct #'s and date carb, intake, distributor,heads, pulleys, fan, valve covers, correct heads on the intake bolts correct coil etc. is what I try to get first. Correctly dated block is important to me also. Cams, rods,whatever crank I can get 1967 Z original first choice if it is good and reasonable, or I could live with a nicely preped 283 crank. Just my opinion. Sam [img]/ubbthreads/images/graemlins/biggthumpup.gif[/img]
Old 11-10-2003, 08:05 PM
rafbody rafbody is offline
The 302 crank did have one notch out of it but the exact crank was also used in 283's. The only difference was the 302 crank was tuffrided. I have examples of both.
Russ
Russ
Old 11-10-2003, 08:16 PM
Ok Russ, I thought they may be the same, but wasn't sure. I think you can get one re-tuffrided if you want to. I don't really think it is necessary. I bet you Ben Wenzel with the D/S national record 1967 Z/28 doesn't worry about his crankshafts. They are probably all 283 cranks he has. Sam [img]/ubbthreads/images/graemlins/[/img] [img]/ubbthreads/images/graemlins/burnout.gif[/img]
Old 11-10-2003, 09:17 PM
I have talked to Ben at the races a few times. He has a great car. Just for clarification, most of the 283 cranks I have seen have a round flywheel flange but, some of them are the same as the 302.
Russ
Russ
Old 11-10-2003, 10:48 PM
JoeC JoeC is online now
Did they have a tapped hole in front of crank? I have one with notch rear flange no tapped hole in front. Seems strange that they relied on just a press fit to hold the H B on.
