Old 12-02-2003, 11:13 PM
mmcporter's Avatar
mmcporter mmcporter is offline
Send a message via AIM to mmcporter
Default LS6--ventline from Fuel Pump
Is the LS6 supposed to have a vent line coming from the fuel pump?
Old 12-02-2003, 11:35 PM
Musclecarkid Musclecarkid is offline
Default Re: LS6--ventline from Fuel Pump
As far as I know, early production (till Jan/Feb) 70 LS6 cars used a #727 short fuel pump and a single fuel line. Code 727 will be in box #33 on the build sheet. Cars built after Feb 70 used the second design long fuel pump with the 1/4 return line to the tank, and Code 768 will be in box #33 on the buildsheet. Cars may have either pump on or close to the time the factory made the change.
Kevin
1970 Chevelle Droptop
Period Correct Speed Parts
482 BBC, M22 or TH400?
Day 2 Super Stock Rocks
Old 12-06-2003, 01:25 PM
mmcporter's Avatar
Thanks for the info.
M
