Old 12-12-2003, 12:49 AM
mike2 mike2 is offline
Default Mapp sensor problem
Having a prob with a 96 model 305 vortec rebuild. It seems to have us stumped.
Problem: On a fresh rebuild, a comp cam(basically the same cam as a GM RV cam) was installed. This being a roller motor we felt all things would be equal. Not so. Just the little difference in the cam caused a loss of vacume. The reading is 15 lbs and it should be 18-20. The mapp sensor reads this and richens the mixture. Thus, fuel mileage and performance goes down the tube.
Has anyone had this problem and what was solution, short of burning another chip and reprogramming computer.
Can a vacume booster be installed and will it do the job?
Help
Old 12-12-2003, 03:24 AM
DaJudge DaJudge is offline
Default Re: Mapp sensor problem
Similar problem, had to reprogram the ECM to get it right. [img]/ubbthreads/images/graemlins/[/img] [img]/ubbthreads/images/graemlins/[/img]
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 12-13-2003, 10:03 PM
Jeff H Jeff H is offline
Turbo City sells a MAP sensor adjuster that fools the computer so you can run a bigger cam.
