Old 12-24-2003, 03:00 PM
allcamaro's Avatar
allcamaro allcamaro is offline
Yenko Premier Member
Default Rear end stamping
I have been looking over my 69 Camaro survivor I just bought from a 89 year old lady in San Jose Ca and the rear end code is not correct as it should be.The code is a PZ and thats right but this is a 12 bolt posi not a 10 bolt as a PZ would be.Wonder if the guy stamping just messed up that day? Rear Code
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1969 RS Z/28 Lemans Blue
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
1992 GMC Yukon 30166 miles
Old 12-24-2003, 03:02 PM
allcamaro's Avatar
Default Re: Rear end stamping
Another. Rear End
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 01-02-2004, 08:15 PM
Kurt S Kurt S is offline
69 PZ is a 12 bolt 2.56 posi. Sounds like an LM1?
Kurt S - CRG
Old 01-02-2004, 11:43 PM
allcamaro's Avatar
Kurt,
I just looked again on the Camaros.net web site where they have nomber bread down and it says 10 bolt posi 2.56 rear end codes
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 01-03-2004, 12:26 AM
bertfam bertfam is offline
This one from the same source, but for 1968 says 12 bolt!
I would say, considering yours is a "proven" 12 bolt, that the 69 listing is probably wrong. However, I don't understand your "F" code for the posi. I've never seen an "F". Only "E" (Eaton), "D" (Dana) and "W" (Warren). Anyone else???
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 01-03-2004, 01:21 AM
Or.... After thinking about it for awhile, another possibility is that the 69 listing is correct, but you have a 68 rear end. What's the date code on the front of the pumpkin? Your stamping is December 11th so the pumpkin should be the same or a litte before that. It will also list the year. The format will be something like:
L108
for December 10th, 1968 (for the 1969 model year).
Also, after looking closer at your first picture, what appears to be an "F" might actually be an "E", just with the lower "leg" stamped very lightly. Kind of hard to tell though.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 01-03-2004, 02:06 AM
OOPS! Check that. The date code will be on the BACK of the pumpkin. Here's an example of mine. "D168" or April 16th, 1968...
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 01-03-2004, 03:05 AM
RPZ28 RPZ28 is offline
allcamaro. PZ is correct for a 1969 2.56 posi rear.Some of the other codes on that list are also incorrect,they're listed as 10 but they should be 12 bolt.
Ron
Old 01-03-2004, 03:05 PM
allcamaro's Avatar
That clears it up,and thanks guys.
1967 Nova SS L30
1967 Chevelle L79
1969 RS Z/28 Red
1970 Z/28 Blue
1967 RS Convertible
1968 Camaro SS
Old 01-03-2004, 09:52 PM
My axle info is correct and the #'s look fine. Most axle lists have errors on them, there's one.
Was my guess right? Is it a LM1 car?
Kurt S - CRG
