Old 04-07-2004, 08:09 AM
82z96ss 82z96ss is offline
Default Need to help identifing corvette.
I have a friend that recently bought a vette. He would like to see what the orginal car was orginally equiped with.
Here is the VIN: 30867S105796
The S maybe a 5.
But then again this doesn't even look like a vin number now that I look like it! Any help.
3 ZZZ's for the 3 kids
Son #2, Son #1, Daughters
82 Z28, 96 Z28SS, 02 ZL1
Old 04-07-2004, 09:33 PM
Pantera Pantera is offline
Default Re: Need to help identifing corvette.
That is part of a '67 S/N (if your numbers are correct) but you need to go back and get the first numbers up to the "S" to be sure. All a Vette sn will tell you is that it is a Cpe. or Conv. and what date it was made.
The rest is on a Sheet that is glued (if you are lucky) to the top of the gas tank.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 04-08-2004, 12:13 AM
DANA/TA DANA/TA is offline
Your Vin # is correct for a 1963 Corvette Convertible. The questionable S in fact stands for the St Louis assy plant. The car is the 5796th 1963 Corvette built. There is no way to tell from the serial # what drive train was in your car. The trim plate will reflect the ECL's that were required for your interior options such as PW, Hardtop, manual or automatic, leather, radio and a/c.
Are your gauges original or restored? Is the center exhaust hanger still there? If so what size are the clamps 2" or 2-1/5"?
Big Mike, DANA T/A #2, '69 L89 IMSA, '76 DeKon Monza, '70 LS5 Conv.
Old 04-08-2004, 07:15 AM
Dana- I'll try and find out your questions. I verified the S/N today and it is correct. I also be checking to see if there is a sheet under the tank.
Thanks for the help
Old 04-08-2004, 11:23 AM
GMH454 GMH454 is offline
If its a 1963 you might have a problem with a tank sticker.
Kind of remember in a past life as a Vette restorer that they did not put Tank Stickers on until around 1967.
Old 04-08-2004, 11:21 PM
GMH454 is correct. You won't find a tank sticker or a build sheet anywhere on the car. Only by inspecting all of the original components of the car and knowing how to eliminate parts that are mismatched, will you be able to come close to deciding what it was built as by the factory. For instance if it has Fuel Injection with a welded right exhaust manifold heat tube and a replacement core support I doubt if it was a factory Fuel Car. Study the assembly manual that is available for the car and cross reference for each option you have to make sure they are installed correctly and that they were available with the other options on the car. Not all options were avalable with the HP motors. Good luck.
Mike
Old 04-11-2004, 09:56 AM
I appreciate the help fellas.
Old 04-12-2004, 05:35 PM
TimG TimG is online now
The redline on the tach will tell you what engine may have come in the car. Solid lifter engines had 6500 RPM redline.
Also, solid lifter cars had 80 lb oil pressure gauge vs a 60 lb. Steep gears, 4.11 & 3.70, only came with HP engines. Solid lifter cars were the 340 horse (carb) and 360 horse fuelie engine cars.
Old 04-12-2004, 07:32 PM
Make sure that the gauges don't look better than the overall car. The gauge faces can be refinished to whatever red line you want. Many cars are made to look like HiPo cars when the the rest of the car doesn't support the gauge cluster. It is a common occurance with Corvettes. A car percieved to be a high perfomance car always brings in the bigger money. Do your homework.
Mike
Old 04-13-2004, 06:28 AM
-------Mike is right. The guages are only a little harder to change than the tires,but rarely do the installers leave them with any dirt on them so they sort of stick out on an unrestored car..........Bill S
