Old 09-11-2004, 12:48 AM
djunod djunod is offline
Default Hone Overdrive
How hard is it to find a working Hone Overdrive used in some Motion cars? How much do they generally sell for?
How about this one from Gear Vendors ?
David
Old 09-11-2004, 02:49 AM
COPO COPO is offline
Default Re: Hone Overdrive
They are on ebay from time to time normally in the $1,200 to $2,000 range. The shifter is very difficult to find. If you don't care about originality, the gear vendors unit is the way to go, however, on some cars the transmission tunnel needs modification.
Old 09-11-2004, 03:33 AM
This is a 73 Corvette with a 454 and TH400.
Hard decision given a choice between the 2.
David
Old 09-11-2004, 05:28 AM
Pantera Pantera is offline
You will have a hard time getting it into that tranny tunnel. With a 4 speed there is a little room next to the tranny, but a Turbo leaves none what so ever. That will make it way out into the passenger side floor.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 09-11-2004, 05:40 AM
You're talking about the Hone, right? Why would it be in the passenger side?
From what I've read, both the Hone-O-Drive and the Gear Vendors are behind the transmission, resulting in a shorter drive shaft.
The Hone has no rebuild parts available... the Gear Vendors would have a warranty & parts available.
David
Old 09-11-2004, 05:48 AM
The lever usually has to go on the passenger side of the tranny tunnel so the driver can reach it. I was looking at Hasslets last year and that is were his lever is.
With the wider and longer tail housing of a Th400 you may have a problem fitting it in.
sorry I just came in from Marguretas with dinner and said it all wrong. Hope that makes better sense?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 09-11-2004, 06:33 AM
jfkheat jfkheat is offline
Here is a picture of the lever on a car I looked at earlier this year.
James
1968 Beaumont SD396
Old 09-11-2004, 06:52 AM
OK, I sort of thought that is what you meant
David
Old 10-03-2004, 04:07 AM
JoeG JoeG is offline
I missed one for 1300 a year ago and one went for 2600 on ebay last year----Gear vendors is a good unit so's American Overdrive---Whatever you decide--Don't shorten your Driveshaft--Get another one made, this way if you have problems you can drop your unit and install your old driveshaft until the overdrive is repaired---
Old 10-05-2004, 04:50 AM
Motion Camaro Motion Camaro is offline
<font color="blue">Good tip Joe.
For the price of a new shaft compared to cutting yours...
I personally would go with a NEW shaft &amp; OD unit.
Good Luck. </font>
Mike Fabian
