Old 10-31-2004, 08:17 AM
tronic72 tronic72 is offline
Default 396, 427 & 454??
Im trying to find some info on the net about the diferances between the 396, 427 & 454? Can a 427 become & 454 and a 396 a 427?
What can be done to a 396?
Old 11-01-2004, 04:25 PM
ANDY M's Avatar
ANDY M ANDY M is offline
Default Re: 396, 427 & 454??
Bore & Stroke.
How much $$$ do you have?
COPO 9561/9737 M40 X11D80
13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22
Old 11-02-2004, 02:25 AM
jfkheat jfkheat is offline
A 396 and a 427 have the same stroke and can use the same crank. A 427 and a 454 both have the same bore and can use the same block. If using a 454 crank in a 427 block the block needs to be notched a little so the crank will clear. 396s and 427 are internally balanced engines and the 454 is externally balanced. The flywheel and harmonic balancer off the 396 and 427 cannot be used on the 454 and the 454 ones cannot be used on the 396 and 427. If this info is not correct, someone please correct it.
James
1968 Beaumont SD396
Old 11-02-2004, 05:26 AM
Unreal Unreal is offline
512 blocks had the relief for the 454 cranks cast in, and were used on both 427 in 69 and 454 in 70.
Old 11-02-2004, 05:30 AM
Chevy454 Chevy454 is offline
JFK pretty much hit the nail on the head. You can, however, set up a 454 to be internally balanced, but it's kinda involvled...
Old 11-02-2004, 06:31 AM
JoeG JoeG is offline
Here's a photo of the block notching jfkheat is talking about
Old 11-02-2004, 07:27 AM
Can a 396 be turned into a 427 or 454?
Thanks
Old 11-02-2004, 07:47 AM
Thanks
Can you fill out your profile?
Thanks
Old 11-02-2004, 09:10 AM
bbdon bbdon is offline
I do know someone who bored a 1969 model 396(325 horse) out to make a 427, and he was successful, I even got a ride. But my understanding is that it is somewhat risky, sometimes it does not work, so I wouldn't try it with a block that was important to me.
Old 11-02-2004, 01:57 PM
Excuse my ignorance but how do I update my profile?
Mark
