Old 12-30-2004, 10:29 PM
69Shelby 69Shelby is offline
Default What Intake to Use on 1968 427 Oval Port Corvette?
I recently purchased a 1968 Corvette Roadster with a 427/390 and a 4 Speed. Car runs great but the problem is that someone put a hi-rise intake and a 750 Holley with a Spacer and wont clear my stock 427 Hood by about 3 inches. I really dont want to go back to the Quadrajet Intake and Dont have the $$$ to fork over for a Factory Tri Power Setup to fit Oval Port Heads (400 Horse) and retain the stock hood. Any ideas/suggestions as to what I can use to retain the Holley and the Stock 427 Hood. I would rather not change it over to an L-88 Type hood. All the info and web sites I have found clearly state "Will not fit Corvette Hood without Modifications" on all of their intakes. Im not ready to axe a perfectly good hood just yet! Does anyone know if there is a "Low Rise" Oval Port Intake Out there that I can Use. Thanks.
Old 12-30-2004, 10:50 PM
Default Re: What Intake to Use on 1968 427 Oval Port Corvette?
948 Intake is the correct one cast iron and says Holly cast in it. kim
Jake is my grandson!!
Old 12-31-2004, 06:05 AM
j69 j69 is offline
I have a GM aluminum 163 intake will that work? Jeff
Old 12-31-2004, 06:07 AM
camarojoe's Avatar
A 163 is a square port, and not a low rise.
Joe Barr
