Old 03-11-2005, 01:43 AM
musclcar musclcar is offline
Default old school tunnel ram and carbs question
i'm about ready to put my edelbrock TR1-X tunnel ram on my sbc and need a few questions answered.was there or is there a spacer or adapter to mount the carbs sideways instead of inline.the carbs i'm going to run are 1850 holley's now i'm trying to get a period correct look is this the correct carb used back in the 70's.on these 1850's i was told i need to run a balance tube for the secondary diaphram so to open correctly.was this how they were set-up back then or did they just run independent of each other. now the fuel line routing i'm currently running the stock 69-70 Z28 metal fuel line for holley carbs.this had a 1/2 line from pump to a brass fuel block then (2) 5/16th lines one to each bowl.i was thinking of running rubber hose from that fuel block to each carb does that sound period correct or is there another way.
72 camaro ss 350 sbc 425hp old school day 2 build-up
Attachments - The Supercar Registry 130911-600m2.jpg 130751-78camaro.jpg 130539-ridgeengine.jpg 130538-ridgerunner.jpg
