Old 03-12-2005, 08:09 AM
Default Mule on chassis dyno today making a 200 mph pull
This is a dyno run made to simulate wind resistance etc.The 200 mph pull was at 12 lbs boost. The drag coefficient program only goes back to 1973 models so they entered the Mule as a 73 Nova which is actually probably a little boxier in shape than a 69 Camaro. It did 0-200 in a calculated 8/10's of a mile. Pulled 120-180 in 6 seconds. Made about 800 hp at the rear wheels at 14 lbs boost. Tires were smoking on the dyno at 120 mph. At 12 lbs boost is was making 750 hp at the rear wheels. It pulled almost 180 mph in 5th at 7200 rpm. I have no torque figures yet. This is all stuff I was told over the phone today so stuff might get clarified more by tomorrow. This is a blast... Dyno video
Attachments - The Supercar Registry 128189-Mulewrite-up.doc 128087-red-hot.jpg
Old 03-12-2005, 08:16 AM
JoeG JoeG is offline
Default Re: Mule on chassis dyno today making a 200 mph pull
Were those the headers getting cherry red??--
Old 03-12-2005, 08:29 AM
Belair62 Belair62 is offline
Yeah they were.. Charley...you may want to invest in a bit of insulating wrap on those headers or carry a good extinguisher !
Old 03-12-2005, 08:37 AM
You think maybe it was making power so fast it just couldn't dump it fast enough out the exhaust??--that was very bright----
Old 03-12-2005, 08:39 AM
Actually I was expecting to see the turbo housings turn cherry...
Old 03-12-2005, 08:40 AM
Ha ! That is normal for turbo setups pulling really hard. Even the wastegates were red.
Old 03-12-2005, 08:43 AM
Allright then break out the Oscar Myers----
The turbo pipes on my buick would creak and pop with the heat and the pipes would get reddish in color but never saw it extend into the headers-that's mucho power--Are the headers ceramic coated Charley??...
Old 03-12-2005, 09:02 AM
budnate's Avatar
budnate budnate is offline
Nice...sounded real smooth...who ever is tuning it is doing a good job...
Old 03-12-2005, 09:03 AM
JChlupsa JChlupsa is offline
WHOA thats pretty stout. Will there be any problem with the paint on the hood bubbling from so much heat??
Old 03-12-2005, 09:53 AM
BBIGG BLOCK 396 BBIGG BLOCK 396 is offline
I bet that thing will almost FLY!Sure sounds cool.I bet the torque numbers are tremendous on that baby!
Bobby Dodson
